Enables DHCP on a specified port in a VLAN.
| port_list | Specifies the ports for which DHCP should be enabled. |
| vlan_name | Specifies the VLAN on whose ports DHCP should be enabled. |
Disabled.
None.
The following command enables DHCP for port 5:9 in VLAN corp:
enable dhcp ports 5:9 vlan corp
This command was first available in ExtremeXOS 11.0.
